Incoming emails
  • 5 replies
  • 2 views
  • Last reply by BBSquared
Greetings,
When I read my incoming emails the same emails are shown in my inbox as new emails no matter how many times I read the same emails.
At times, I will mark the emails as unread, read them and I have to do this exercise several times until I either delete the message or print the email.
Are there any updates to fix this issue?
Please help! Thanks
Greetings, When I read my incoming emails the same emails are shown in my inbox as new emails no matter how many times I read the same emails. At times, I will mark the emails as unread, read them and I have to do this exercise several times until I either delete the message or print the email. Are there any updates to fix this issue? Please help! Thanks
So far so good....thank you!!!!
All Replies (5)
Does it make any difference if you right-click the Inbox in the Folder Pane, Properties, Repair Folder?
Sorry, I do not understand - are you asking if I tried right-click..... and if yes, no I did not try it but will do so now
Yes, right-click, select Properties, Repair Folder (see picture).
Following up to my post on 3/15...I tried the repair folder numerous times and the problem persists. Other solutions??
